Posted: Fri Jan 20, 2012 11:39 am |
My engine has begun making a high squeaking sound for approx 20-30 seconds at a time. this usually happens when i start it up from cold but now and then i hear it ever so slightly. to my limited knowledge this sounds like a fan belt? Iv only had the car a couple of weeks and its under warranty, id just like to able to explain it to them if it doesnt do it when i take it back!
It started doing this a few days after i got it home very slightly, but its definately getting louder and longer
Cheers
Posted: Fri Jan 20, 2012 11:47 am |
When i had a very similar problem it was thr fan belt/aux belt and few other parts linked to it...
Posted: Fri Jan 20, 2012 12:00 pm |
Aux belt. If it gets worse defo!!
Posted: Fri Jan 20, 2012 12:22 pm |
Definitely aux belt replacement time
Posted: Fri Jan 20, 2012 12:23 pm |
Sort it sooner rather than later if it fails or one of the pulleys fail it can get stuck in the cambelt and take out the engine
Posted: Fri Jan 20, 2012 1:17 pm |
excellent cheers, ddidnt think it was that serious!
Posted: Fri Jan 20, 2012 1:36 pm |
Ajo123 wrote: |
excellent cheers, ddidnt think it was that serious! |
Its probably not but better to get it looked at just incase
Posted: Fri Jan 20, 2012 1:56 pm |
it happens before.
Posted: Sun Jan 22, 2012 4:20 pm |
Further to this, I was looking my car over today and noticed there is no heatshield/cover on the underside of my bonnet. Is there supposed to be one here, and if so, does it cover the two vents in the bonnet of every 206?
Im thinkning this may be a cause of the problem if moisture is getting into my engine bay, as the noise was noticably worse during this crappy weather the last week or so
Posted: Mon Jan 23, 2012 9:28 am |
Ajo123 wrote: |
Further to this, I was looking my car over today and noticed there is no heatshield/cover on the underside of my bonnet. Is there supposed to be one here |
Not all 206's have the under bonnet sound proofing fitted.
