Latest: Puggingalong
Overall: 17129
Online Now [248]:
Visitors: 247
Today: 14487
Total: 101221678
Forums › The Car › 206 Problems › side light comes on when braking :/
QuArTz
PostPosted: Sat Jan 28, 2012 8:52 pm Up
Trade Rating: +16
As above, today I noticed that when I press the brake light, not only the do all three brake lights come on but so does my off side, side light.
when the lights are on and I press the brake the side lights is fine.
My side lights are l.e.d but it's the first time ive noticed this odd side light trick.
parkesie
PostPosted: Sun Jan 29, 2012 1:05 am Up
poor earth to the off side cluster brake light is using the side light for a earth. clean up connections and double check the fitment of bulbs.
Signature p**s
iainlovatt
PostPosted: Sun Jan 29, 2012 3:37 am Up
i would have to agree with this, also what lights are they?
Very Happy
(My Garage)
Martind
PostPosted: Sun Jan 29, 2012 4:53 am Up
I had a similar problem with my CC when it had Lexus Lights.
The problem with mine was a loose wire on the where the lights plugged into the car.
Problem solved by connecting the wire properly.
Silvery206
PostPosted: Sun Jan 29, 2012 5:41 am Up
Also happened to me when I replaced the brake light bulb with the wrong type of bulb.
Silvery 206
QuArTz
PostPosted: Sun Jan 29, 2012 6:59 am Up
Trade Rating: +16
Thanks for the replies guys..
Will see if any of your suggestions fix this..
PostPosted: Sun Jan 29, 2012 7:05 am Up
i would say wrong type of bulb, eg a double filament in a single filament holder
