Posted: Mon Sep 10, 2012 2:34 pm |
does anyone know if its difficult to replace a control arm bush n can it be done at home or is it a garage job ? pleas help
Posted: Mon Sep 10, 2012 3:18 pm |
Trade Rating: +16
bush? im sure the whole arm needs doing? and would be a garage job if you have no idea what you are doing.
had both mine done and track rod ends for £30 at hi q
Posted: Mon Sep 10, 2012 3:55 pm |
you can certainly press out/in a new bush onto the wishbone
but you will need a press
Posted: Mon Sep 10, 2012 3:57 pm |
We have a 50 ton press at work
No needed to do any bushes yet on the 206
Posted: Mon Sep 10, 2012 4:00 pm |
MrBSI wrote: |
No needed to do any bushes yet on the 206  |
that probably worth a lot of money
Posted: Tue Sep 11, 2012 2:39 am |
Just replace the whole arm as more than likly the ball joing will be worn too, try and get the best you can afford as it wont last you 6 months if its cheap.
Passenger side is a little harder as the drive shaft pops out loosing oil but its the same meathod both side, i did 2 on my at the weekend it took around 2 hours so quite easy to be honest
Posted: Tue Sep 11, 2012 5:17 am |
thanks guys by sounds of it best to get it done at garage
