Latest: eltel666
Overall: 17146
Online Now [54]:
Visitors: 53
Today: 10655
Total: 116202254
Forums › The Car › 206 Problems › fan not working
fan not working
m4tth3w
PostPosted: Fri Feb 03, 2012 11:09 am Up
I'm pretty sure my fan is dead as I never hear it and car goes into red when stood .nun traffic, pretty quick.
Any tips on what to check before I invest in a new one?
Pan24v
PostPosted: Fri Feb 03, 2012 11:23 am Up
Check the fuse in the engine compartment fuse box, its fuse No7 - bottom right as you look in the fuse box its a 20 amp.
Mine had blown so checked the fan assembly by taking off the black upper grille between the headlamps to find the motor had seized solid!
I haven't renewed as yet as i have my engine in bits but there are various types.
Are you doing the job yourself?
2001(Y) 206 2.0 HDi RHY
Mattie-RS
PostPosted: Fri Feb 03, 2012 11:38 am Up
OR if you use the Search function of this website you'd find that this has been covered and solved many a time!!
PostPosted: Fri Feb 03, 2012 11:54 am Up
This has been covered loads recently. You'll find everything you need on other topics.
m4tth3w
PostPosted: Fri Feb 03, 2012 12:56 pm Up
thanks for the positive response pan24v Very Happy
Daveb206
PostPosted: Fri Feb 03, 2012 3:36 pm Up
Unplug it and run 12v through it. If it works cheack fuses.
Love it
m4tth3w
PostPosted: Fri Feb 03, 2012 4:26 pm Up
Cheers, where is the fan by the way and where does the wire plug in? I can't find it??
Mattie-RS
PostPosted: Fri Feb 03, 2012 4:30 pm Up
I see you edited this, It doesnt annoy us!! but us that know the answers to all your problems just dont answer Wink
Judging by your last post you could do with the help!
PostPosted: Fri Feb 03, 2012 4:32 pm Up
I have a fan relay and resistor loom if you need one...it's second hand but fully functional
Daveb206
PostPosted: Fri Feb 03, 2012 4:53 pm Up
Get your self a workshop manual. It might plug in above the fan near the slam pannel.
Love it
m4tth3w
PostPosted: Fri Feb 03, 2012 5:22 pm Up
I have a better idea, anyone have a 180 for sale?
Cheers for replies Smile
Daveb206
PostPosted: Sat Feb 04, 2012 7:43 am Up
Swop for 1.4 that has a working fan lol
Love it
PostPosted: Sat Feb 04, 2012 8:00 am Up
Where do you think a 206 radiator cooling fan is going to be?
Its going to be attached to the radiator, try looking through the grill, you will find what your looking for.
m4tth3w
PostPosted: Sat Feb 04, 2012 8:07 am Up
I did and I couldn't see it, upon further investigation the fan seems to be located in a roundish plastic moulding behind the bulk head.
m4tth3w
PostPosted: Sat Feb 04, 2012 8:16 am Up
I seem to have two radiators?
A bigger one at front and a newer looking smaller one behind it,
Do gti's have oil cooler's or is it more likely that it just has a newer radiator bolted to the old one?
I apologise for being automotively thick. Smile
