Latest: tbafonso
Overall: 17130
Online Now [176]:
Visitors: 175
Today: 66775
Total: 103733575
Forums › The Car › 206 Problems › need help asap
need help asap
herb-16v
PostPosted: Sat Feb 04, 2012 7:57 am Up
hi everyone my sisters 206 1.1 look had a probably with injector number 3 i changed it about 4 month ago and all was good till few days ago when started missing again, it went to garage as engine light come on and code was p0265 injector cylinder 2 circuit high, i taken all injectors out cleaned them put them back and was running fine for about 2mile and started missing again but no engine light come on so went to garage plugged in and was no codes come up so he thinks the rubber o seals need changing as he thinks its letting air in past them, what do you`s think??? also i was looking at getting 4 new injectors for it part code 1984C9 so i was told and these in the link are the ones are fitted to car but i got told 1.4 might fit as they have the same part number is this right?
www.ebay.co.uk/itm/150...1423.l2649
HI
PostPosted: Sat Feb 04, 2012 8:24 am Up
Remember injector / cylinder number 1 is the GEARBOX end on a 206 Wink
Plenty of people on here have changed the wrong injector before Laughing
Injector seals should always be replaced whenever they are disturbed.
herb-16v
PostPosted: Sat Feb 04, 2012 8:33 am Up
yer i found that out when i changed number 3 i went the wrong way lol i will have to change the o rings and see what happens, any 1 got any injectors for sale?
HI
