Latest: Stu-mill
Overall: 17131
Online Now [313]:
Visitors: 312
Today: 88383
Total: 104773929
Forums › The Car › 206 Problems › Rear end clunk/bang
Rear end clunk/bang
GTSX
PostPosted: Thu Feb 02, 2012 4:51 am Up
I'm getting a clunk or bang from the rear right handside suspension at present. It's too cold for me to invetsigate outside at present and I don't have a garage to work in or money to take it somewhere.
I thought the rear suspension was just a torsion bar but the noise is like a worn bush.
Are there any in the back axle?
Big_Rich180
PostPosted: Thu Feb 02, 2012 5:00 am Up
There are bearings in the rear axle that will die at some point, quite an expensive job IIRC.
Fifer
PostPosted: Thu Feb 02, 2012 9:58 am Up
Changed my duff axle bearing today. Took 5 hours on drive with coffee breaks. Bugger of a job and needed my sledge hammer. Or you can replace the whole axle (which is a lot easier). Recon approx 400 scrappies about 125 but you don't know how long they will last. To check jack up the car and try to move the wheel. Or take it to kwik fit and get them to check. They diagnosed mine for free. It's a common problem.
There is a how to in the section and a good set of videos on you tube.
Forgot to add, another symptom is poor handling as the rear wanders a bit and inside edge tyre wear. Also the wheel will sit in at the top although mine only did this sometimes.
1.4hdi 02
GTSX
PostPosted: Sun Feb 05, 2012 5:27 am Up
Ok thanks, well that explains the other issues that I have been experiencing?
