Forums › The Car › 206 Problems › Body Panels |
Posted: Sun Feb 12, 2012 3:55 am |
Due to some ice on the road I need some body panels. I've found most of what I want on e-bay but I can't find a sill panel. The drivers side got a dent in it from a rock, just the first 6 inches.
Where can I get a drivers side sill panel
Posted: Sun Feb 12, 2012 4:46 am |
GTSX wrote: |
Where can I get a drivers side sill panel |
Peugeot main dealer, there WELDED on so it needs a PROFESSIONAL to replace it!
Posted: Sun Feb 12, 2012 4:48 am |
Peugeot dealer, or you'll need to cut it off another car which will be difficult. £320.
Posted: Sun Feb 12, 2012 5:19 am |
there is a reason why you can't find those parts on ebay
