Latest: SA01
Overall: 17138
Online Now [166]:
Visitors: 165
Today: 100491
Total: 111241741
Forums › The Car › 206 Problems › Overheating problem
Overheating problem
eggy6832
PostPosted: Sat Feb 04, 2012 5:42 am Up
My car is massively overheating. I topped up coolant level yesterday yet today The stop light was flashing my radiator top house is red hot and just wondering what it could be I had the water pump replaced just before September last year, so it shouldn't be that should it?
Any help greatly appreciated
owner of a 206 gti
AshH
PostPosted: Sat Feb 04, 2012 5:44 am Up
Could be a blockage in the pipes so water is not circulating proppa!
Team - 180
Team - ATM!!!
eggy6832
PostPosted: Sat Feb 04, 2012 5:52 am Up
Well was thinking of flushing radiator would that help? Would it not be thermostat?
owner of a 206 gti
AshH
PostPosted: Sat Feb 04, 2012 5:55 am Up
Well if you check the stat, then do a flush it may help. Had the same problem with the Fiesta not long ago! Turned out to be both stat and hoses :/ lol
Team - 180
Team - ATM!!!
eggy6832
PostPosted: Sat Feb 04, 2012 6:03 am Up
Lol fair play jus hoping it's not head gasket
owner of a 206 gti
AshH
PostPosted: Sat Feb 04, 2012 6:12 am Up
If your worried it being the head get a compression test done!
Team - 180
Team - ATM!!!
eggy6832
PostPosted: Sat Feb 04, 2012 6:26 am Up
But I've got no loss of power just overheating
owner of a 206 gti
Daveb206
PostPosted: Sat Feb 04, 2012 6:50 am Up
Take your stat off. Boil the kettle pop the stat in some hot water and see if it opens. If not replacee.
Love it
AshH
PostPosted: Sat Feb 04, 2012 6:51 am Up
worth a flush and stat check then, if that doesnt solve, get it compression tested!
Team - 180
Team - ATM!!!
PostPosted: Wed Feb 08, 2012 4:53 pm Up
If you are going to the trouble of taking the stat off just replace it. Keep the old one though just in case!
However, if the stat is stuck completely shut the top hose should not get hot! I guess the failure may be that it doesn't fully open but that is a relatively rare type of failure.
I am not sure if water pumps fail on these, there are plastic impellar type water pumps that fail on many other manufacturers cars but I don't know enough about these engines to know if it is common failure on these but it is another item to consider.
