Posted: Thu Feb 09, 2012 2:07 pm |
could anyone help with a diagram of rear abs set up with drums, where the sensor is located ect as think someone has changed the rear of mine and did away with it.Thanks
Posted: Thu Feb 09, 2012 2:17 pm |
Posted: Thu Feb 09, 2012 2:26 pm |
i cant seem to see the abs sensor in that photo and cant scroll down side bar bit to get number of it?
Posted: Thu Feb 09, 2012 4:15 pm |
abs sensor is not on that page and i have already given you the number
Posted: Thu Feb 09, 2012 4:36 pm |
Had a quick look on mine other day as I need a new axle. Pretty sure the trailing arm has a mounting for the abs sensor, Its not part of the drum/backing plate assembly
Posted: Thu Feb 09, 2012 4:39 pm |
ej2_sir wrote: |
Had a quick look on mine other day as I need a new axle. Pretty sure the trailing arm has a mounting for the abs sensor, Its not part of the drum/backing plate assembly |
nice to know that...
i only sure disc axle got a hole on the arm to plug the abs sensor as my drum axle has no abs
Posted: Thu Feb 09, 2012 4:55 pm |
lol dont think mine will for much longer as i cant find a bloody 2nd hand beam with drums an abs for love nor money!!
Posted: Thu Feb 09, 2012 6:16 pm |
Seabook wrote: |
abs sensor is not on that page and i have already given you the number |
It also doesnt take 3 different new threads started by the same person to sort out the same problem
Posted: Fri Feb 10, 2012 3:45 am |
ej2_sir wrote: |
lol dont think mine will for much longer as i cant find a bloody 2nd hand beam with drums an abs for love nor money!! |
Why not simply put a disc axle on then?
Posted: Fri Feb 10, 2012 1:16 pm |
Sorry for the thread hijack but with regards to the post above, Someone has offered me a disk beam with abs from a pre plex 2000 model. Could I fit this and use the multiplex wiring/abs sensors from my drum beam to make it all work? Thanks in advance and sorry again
