Latest: Worthy967
Overall: 17143
Online Now [564]:
Visitors: 563
Today: 115087
Total: 115146152
Forums › The Car › 206 Problems › Exhaust smoking, leaking, engine struggling in lower gears..
hammer206
PostPosted: Sat Jan 28, 2012 9:46 am Up
Hi all Ive got a 1.4 Zest and today its all of a sudden gone all wrong
Basically when it starts on the 3rd or 4th attempt its chucking out loads of white smoke and the engine sounds like its struggling, I drove it earlier and this is only happening in the lower gears once i get out of third it seems to be ok
No warning lights on but the exhaust is leaking a little. Anyone got any ideas what the hells happened? Thanks in advance
hammer206
PostPosted: Sat Jan 28, 2012 10:11 am Up
Engine won't turn over at all now either
PostPosted: Sat Jan 28, 2012 10:17 am Up
Have you checked for headgasket failure?
PostPosted: Sat Jan 28, 2012 10:48 am Up
Turns over but wont start OR wont even crank?
hammer206
PostPosted: Sat Jan 28, 2012 11:50 am Up
Earlier it just wouldn't turnover now its just doing this
www.youtube.com/watch?v=CeVay5EMzCQ
Getting worse by the minute :s
hammer206
PostPosted: Sat Jan 28, 2012 11:55 am Up
I had a headgasket problem afew months ago but whats happening now has never happened before, the head gasket isnt leaking like it used to so I dont think its the same problem as before anyway
PostPosted: Sat Jan 28, 2012 12:00 pm Up
Have you checked the oil level with the dipstick?
I would be tempted to remove all 4 of the spark plugs & then try cranking it over.
Its sounds like its either seized or the cylinders are full of coolant.
Nic_206
PostPosted: Sat Jan 28, 2012 12:13 pm Up
sounds likes its seized mate when I had the 1.6 in mine that seized and was the same as yours in the video.
Ford focus st3 daily driver
Team: Red 20v6
hammer206
PostPosted: Sat Jan 28, 2012 12:18 pm Up
ah right ok, I'll give it a go tomorrow and see what happens, thanks all
PostPosted: Sat Jan 28, 2012 12:35 pm Up
This is what happens when you don't maintain and service your car regularly
PostPosted: Sat Jan 28, 2012 2:16 pm Up
I get the feeling its gonna be expensive, head gasket at least or more likely another lump needed.
PostPosted: Sat Jan 28, 2012 2:33 pm Up
Just pull the dipstick out and check the level, doesnt sound to good though.
leigh_boy
PostPosted: Mon Jan 30, 2012 8:30 am Up
could be low battery , check all your levels, and get a mate with jump leads to help jump it.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
hammer206
PostPosted: Fri Feb 10, 2012 12:19 pm Up
just got it back turns out it was a blown head gasket.. again, replaced free of charge with a different part
PostPosted: Fri Feb 10, 2012 12:43 pm Up
unless they skim the head otherwise it is just a waste of time
