Latest: tbafonso
Overall: 17130
Online Now [281]:
Visitors: 280
Today: 52987
Total: 104408231
Forums › The Car › 206 Talk › Fog Lights
Fog Lights
egouder
PostPosted: Mon Feb 13, 2012 5:38 am Up
Ok, I had my car for over a year now, I have a 1999 1.4l 5door.
I have the non-sport front bumper with fogs, but for some reason I do not even have the function to switch them on from the stalk, when i look into them it seem that they do have bulbs, maybe they are not wired?
is it easy to do?
thanks
abs06
PostPosted: Mon Feb 13, 2012 8:55 am Up
i think IIRC from other threads, you need to wire it in to a new stalk with the fog bit on, then have the computer sorted...
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Mon Feb 13, 2012 8:58 am Up
Op has a NON plexed car, BSI unit doesnt come in to it Wink
egouder
PostPosted: Mon Feb 13, 2012 9:31 am Up
I haven't understood you guys :S can you talk in simpler works? whats iirc? mine is a non plexed.
PostPosted: Mon Feb 13, 2012 10:00 am Up
I think there was a thread about retro fitting front fogs which had the wiring diagram on it and controlled them through a separate switch on the dash. Can't be bothered using the search function to find it so I will let someone else post up the link.
PostPosted: Mon Feb 13, 2012 10:10 am Up
Peugeot used to sell a retro fit kit for the front fog lamps that had everything in you needed.
Fog lights, replacement headlamp stalk, complete fog lamp wiring loom etc.
The non plexed version isnt listed any more, they do show up from time to time on Ebay, if your not in a rush to get them working then I would keep an eye out on Ebay.
