Posted: Fri Feb 17, 2012 9:16 am |
what is this part and what does it do?? i was changing my discs on my gti and this was cracked.
this is where it came from
a quick respones is needed as it needs fixing asap. cheers!!
Posted: Fri Feb 17, 2012 9:18 am |
Its an ABS ring from the driveshaft.
Posted: Fri Feb 17, 2012 9:24 am |
can i drive my car without it?
Posted: Fri Feb 17, 2012 9:25 am |
pnut_man wrote: |
can i drive my car without it? |
Yes BUT the ABS system wont work & it will fail the MOT.
You can get a new ABS ring & get it fitted OR replace the complete drive shaft.
Cracked ABS rings are a common 206 GTI problem
Posted: Fri Feb 17, 2012 9:27 am |
ahh. is it a simple job to fix?
Posted: Fri Feb 17, 2012 9:31 am |
pnut_man wrote: |
ahh. is it a simple job to fix? |
That depends on your skills & tools.
You need to remove the driveshaft from the hub to get the new ABS ring fitted on.
A new ABS ring is pretty cheap, someone did post a link before on here to a supplier.
If your handy with the spanners then its a pretty cheap fix.
Posted: Fri Feb 17, 2012 9:50 am |
Posted: Fri Feb 17, 2012 11:09 am |
Cheers. ill be getting them from lt motors i think, only £12.
