Latest: sparrowdclxvi
Overall: 17139
Online Now [137]:
Visitors: 136
Today: 18047
Total: 113545661
Forums › The Car › 206 Problems › Ouside temp sensor
Ouside temp sensor
james180
PostPosted: Fri Feb 17, 2012 10:43 am Up
Just fitted a new sensor but the temp displays -- now as if its not connected?
Before it would would show 40 all the time.
Do i need to reset anything or could it be a faulty sensor from Peugeot?
Just a thought but do the wires need to go a certain way? I fitted it the same way as the one i removed though???
Understeer is a crime.
PostPosted: Fri Feb 17, 2012 10:45 am Up
It should work when you turn the ignition on.
Did you crimp the connections or use the correct method of solder & heatshrink?
-- is no signal from sensor.
james180
PostPosted: Fri Feb 17, 2012 10:46 am Up
Solder and heatshrink.
Definatly got a good connection on both wires.
PostPosted: Fri Feb 17, 2012 10:49 am Up
Unplug the mirror & measure the resistance across the 2 terminals with the black wires.
james180
PostPosted: Fri Feb 17, 2012 10:58 am Up
4.25
Just wiggled the plug and the display came on,better fix the dodgy connection.
Thanks for the quick reply.
james180
PostPosted: Fri Feb 17, 2012 11:09 am Up
All working properly.One of the connections had a bigger gap than the other so bent it in with a small screwdriver.
Thanks MrBSI.
PostPosted: Fri Feb 17, 2012 11:37 am Up
Thanks MrBSI.
Thumb Up
PostPosted: Fri Feb 17, 2012 12:58 pm Up
I like when problems get solved so quick :D,MrBSI the handy man here Wink
