Latest: Beduff1977
Overall: 17134
Online Now [96]:
Visitors: 95
Today: 45958
Total: 107151375
Forums › The Car › 206 Problems › head gaskit going or just a dodgy seal
Jmoore8419
PostPosted: Mon Feb 20, 2012 5:02 am Up
i recently got a pug206 1.4 glx 1999 it has 77.000 on the clock. upon noticeing an oil leak a week later i thought Oh crap now what!! its coming from left hand side near the bottom its not a major one but enough to make u worry. there's no sign of oil contamination by water But the water has gone down since filling saturday. no over heating and no steam or hissing when i undo water cap. Has anybody else had this problem or know what could b the problem?
jmoore
mehoolkmusic
PostPosted: Mon Feb 20, 2012 6:06 am Up
Might be your water pump or thermosta
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
mehoolkmusic
Jmoore8419
PostPosted: Mon Feb 20, 2012 1:48 pm Up
well the water seems to b swirling around. car still running fine but still leaking still no sign of gaskit going... taking it to garage tomoz morning will update then
jmoore
deanparkr
PostPosted: Mon Feb 20, 2012 1:50 pm Up
Take a look at this: www.206info.co.uk/Foru...40386.html
Might be the same kind of oil leak? (Scroll down for pictures)
2002 1.4LX
Jmoore8419
PostPosted: Mon Feb 20, 2012 3:34 pm Up
the oil is in that general area the seal on the rocker box does look screwed i will replace that and see if it stops will let ya know how i get on thanks for the help
jmoore
PostPosted: Mon Feb 20, 2012 4:00 pm Up
Be careful doing up the rocker cover bolts, if you do them up to tight you will bend the rocker cover causing your nice new seal to start leaking Wink
Jmoore8419
PostPosted: Tue Feb 21, 2012 6:09 pm Up
upon taking the cover off and looking at the oil there is still no sign of mayo/water im guessing i should keep and eye on it and maybe give it oil and filter change before spending loads of money on new head gaskit
jmoore
PostPosted: Wed Feb 22, 2012 3:10 pm Up
Some people overfill the water, when you drive it gets hot, expands and overflows. Then it cools and the level is below where it was so they top it up again. You aren't filling it above the max marker on the expansion tank are you?
Jmoore8419
PostPosted: Wed Feb 22, 2012 4:35 pm Up
Its hard to see where the max water line is the bottle is very hard to see thro for sum reason. Took the car out for a long drive today and no over heating or smoke or any dodgy goings on oil went down a lil but that is all!! Im off to sheffield thursday evening i have confidence it will b ok! wish me luck
jmoore
PostPosted: Wed Feb 22, 2012 4:50 pm Up
If its between the block and cylinder head it is the headgasket
Replace the cambelt too if it hasnt been done
Its an extremly common failure the oil seal, so dont worry just get it done
Jmoore8419
PostPosted: Wed Feb 22, 2012 5:14 pm Up
cant i just replace the seal?
jmoore
PostPosted: Thu Feb 23, 2012 9:45 am Up
Take it of & stick it in the dishwasher if you have one Wink
Jmoore8419
PostPosted: Mon Feb 27, 2012 5:56 pm Up
got to sheffield with the oil leak and no problems at all only had to put water in... now im even more confused lol hmmmm
jmoore
PostPosted: Tue Feb 28, 2012 4:56 am Up
Is the water bottle difficult to see through because it is a brown colour. That is a good sign of head gasket failing or has previously failed and wasn't cleaned (very few people bother) when the gasket was fixed.
