Latest: sparrowdclxvi
Overall: 17139
Online Now [175]:
Visitors: 174
Today: 32433
Total: 113103803
Forums › The Car › 206 Problems › Rear washer hose!!!
Rear washer hose!!!
james180
PostPosted: Sat Mar 10, 2012 10:22 am Up
My rear washer hasnt worked since i got the car so i decided to investigate. I could hear the motor working so decided to trace the hose to find out what was wrong.
I found this above the drivers seatbelt area. Shocked
Looks like it has burned and melted in half. Couldnt see anything else around it to cause this and seeing as it only carries water Im completely baffled by it. Confused Does anyone have any ideas what could of caused it???
Understeer is a crime.
PostPosted: Sat Mar 10, 2012 10:29 am Up
Somebody been doing some welding?
PostPosted: Sat Mar 10, 2012 10:40 am Up
Wonder if the car has been repaired in the past & if it has was it done correctly Laughing
PostPosted: Sat Mar 10, 2012 10:44 am Up
What route does the hose take along the car?
james180
PostPosted: Sat Mar 10, 2012 10:48 am Up
Peeled back the rubbers but no sign of any repairs at all.Been under the car quite a lot also and no sign of any accident damage anywhere??
This was in between the roof lining and the roof?
PostPosted: Sat Mar 10, 2012 11:05 am Up
Drivers wing > A pillar > under headlining on drivers side > drivers C pillar > boot
james180
PostPosted: Sun Mar 18, 2012 12:16 am Up
Im guessing this is not a common problem on the 206 then.
Cant for the life of me think what could of caused this??? Confused
