Online Now [392]:
Visitors: 391
Today: 10692
Total: 105339210
Forums › The Car › 206 Problems › What sized torx bolt and bleed nipples?
ssjgoku101
PostPosted: Tue Jul 24, 2012 2:18 pm Up
Heyo
I've changed the rear brake discs on my xsi 1.6 and the bolts that come with the discs are rubbish. You can't tighten them enough for the hole size. What sized torx bolts do I need to buy?
Also a bleed nipple has sheered off. I've got the tools needed to remove the thread but i'm not sure what size nipples I need to replace it, anyone have an idea?
Cheers guys
Baz
PostPosted: Tue Jul 24, 2012 2:33 pm Up
Just go to the dealer, if they sell the nipples they will be dirt cheap
PostPosted: Tue Jul 24, 2012 2:39 pm Up
About £5 each.
ssjgoku101
PostPosted: Tue Jul 24, 2012 2:42 pm Up
Ebay sell packs of 4 for a fiver. I'm trying to be a cheapskate and save money but i'm not sure what sized ones to get.
Baz
ssjgoku101
PostPosted: Tue Jul 31, 2012 4:37 pm Up
Just in case anyone needs to buy new bleed valves, the size you need is M7,27mm long valves.
Baz
