Latest: tc.206
Overall: 17147
Online Now [52]:
Visitors: 51
Today: 8946
Total: 116505513
Forums › The Car › 206 Problems › Help!
Help!
scmitt
PostPosted: Mon Apr 23, 2012 3:09 pm Up
Hi. Im new to this site but hope some of you may be able to help.
My son bought a 206 recently but has had some problems. He had a major oil and water leak with steam coming out of the bonnet. I thought head gasket. I have changed the head gasket, cam belt, aux belt. put it all back together. When it comes up to temp it still has steam coming from rad. Its like water is boiling in the rad. I have checked thermostat, flushed and bled coolant. I have not heard the fan come on yet. Am i right to think that this will be the problem????? Any advice would be greatly recieved
jsmith
lmilligan
PostPosted: Mon Apr 23, 2012 3:21 pm Up
Welcome Waving o/ what engine has the car got?
scmitt
PostPosted: Mon Apr 23, 2012 3:32 pm Up
Hi. Its a 1.1 206lx with power steering and air con
jsmith
anton1989
PostPosted: Mon Apr 23, 2012 3:35 pm Up
Trade Rating: +16
i had a problem like this, it was my rad, it had a leak from where the road works kept hitting it from underneth, the rad leaking stopped my fan working for some reason? changed my rad everthing was ok again.
mine was also a 1.1
138Andy
PostPosted: Mon Apr 23, 2012 3:47 pm Up
the resistor may have gone on his rad fan so it wont kick in at all the car will just over heat as for steam ? :/ you may have a crack / split pipe ? :/
scmitt
PostPosted: Mon Apr 23, 2012 3:48 pm Up
Thanks. Is the resistor easy to check/change?
jsmith
scmitt
PostPosted: Mon Apr 23, 2012 3:50 pm Up
I think the steam was just because i was following the manual instructions regarding refilling coolant. It said just to idle until the fan came on and off twice. I was waiting a while and it didnt! So i think it was just overheating!
jsmith
Jensen
PostPosted: Tue Apr 24, 2012 1:06 am Up
mine was also a 1.1
I had the same problem as this, my radiator had a slight crack in it, changed the rad and it was fine Smile
PostPosted: Tue Apr 24, 2012 1:09 am Up
Did you check the head to see if it was warped?
scmitt
PostPosted: Tue Apr 24, 2012 2:48 pm Up
I did the best i could. I used a steel ruler to try to see any obvious warping but it all looked pretty good
jsmith
