Latest: Beduff1977
Overall: 17134
Online Now [477]:
Visitors: 476
Today: 59584
Total: 109230459
Forums › The Car › 206 Problems › GEARBOX OILD LEVEL CHECK - 1.4 MANUAL
jwoo06
PostPosted: Wed May 02, 2012 5:36 am Up
Hi there,
I have a Peugeot 206 1.4 MANUAL and was wondering how to check the gearbox oil level?
Please help!!
Many thanks
Original and Mint 2005 Peugeot 206 1.4
Andrew
PostPosted: Wed May 02, 2012 11:57 am Up
I don't think there is a way to check the level apart from drain the lot and refill to the correct amount
My 206 thread
www.detailedbyandrew.com
PostPosted: Wed May 02, 2012 12:12 pm Up
Fill / level plug on the side of the gearbox, not sure if its still fitted on the later MA box.
Andrew
PostPosted: Wed May 02, 2012 12:38 pm Up
There isn't one on mine (2007) Sad hopefully his being a 2005 it might have one
My 206 thread
gazza82
PostPosted: Wed May 02, 2012 2:38 pm Up
I think the 1.4 models have a filler plug on the end of the box ... but I'm not 100% sure if the petrol box is same as diesel box like ours. There has to be one though ... otherwise how do you fill them up after draining it (or loosing oil because the drive shaft pulls out when replacing the wishbone ... been there, got the T-shirt! Wink
Normal way is to take filler plug out and top up slowly until it runs back out the plug hole. The car HAS to be level though and this isn't easy when you have to take the n/s wheel off to get to the gearbox! Not the greatest design in the world! Rolling Eyes
Tiago
PostPosted: Thu May 03, 2012 2:18 am Up
I have a whirring noise coming from my car occasionally which I thought it was the gearbox so I replaced the oil by draining and filling through the breather hole, it takes 2 litres. I couldn't find a level/fill hole.
