Posted: Fri May 04, 2012 4:22 am |
Hi everyone, before i state my problem i have searched for endless hours on this and cant find an answer.
Basically i have h4 frosted, no wires under them i could see obviously on a 02 GLX that would allow me to put the h7 straight in, but my question is the two grey plugs from peugeot and the 6pin connections, do i need this for each headlight on the car ? making it 4 connections and 12 pins as both the headlights take 4 h7 bulbs? or do the order codes posted on here supply for each headlight? thanks
(I also have a company who did my doors changing he bci setting to duel optic) so all i am waiting on is the connections needed for them to solder into my loom
Posted: Fri May 04, 2012 6:26 am |
Question is a bit confusing but here's what I can interpret. Even though each headlight has two h7 bulbs you only will have one connector for both them to work. So you dont need 4 connectors for both headlights only 2 like your setup is now.
Posted: Fri May 04, 2012 9:42 am |
Thanks mate, sorry i wasnt quite sure how to word it, ordered anyway
Posted: Fri May 04, 2012 9:49 am |
No problems buddy
