Latest: S2cgm
Overall: 17178
Online Now [73]:
Visitors: 73
Today: 29816
Total: 136817260
Forums › The Car › 206 Problems › GTi 180 Gear lever adjustment
lisaskye
PostPosted: Tue May 22, 2012 7:22 am Up
All
My GTi 180 gear lever seems to have a lot of play in 5th gear , move it to the left and all the play is good. Seems like there is some adjustment may be requried or the gear linkage bushes are gone.
Before I pull apart does anyone know the procedure to ensure the cables and lever are correctly aligned to the correct gearing on a 180
Dave
ramigojag
PostPosted: Tue May 22, 2012 8:46 am Up
Mine is the same and we had a Peugeot 307 SW at work the other day that was the same I think it's common on peugeots not sure of a way to adjust but if you find one let me know
