Latest: Beduff1977
Overall: 17134
Online Now [434]:
Visitors: 433
Today: 9574
Total: 107322012
Forums › The Car › 206 Problems › Rear vibration above 50mph
PostPosted: Tue Jun 12, 2012 4:50 am Up
Hope someone can offer some advice,
My 206 1.4hdi has developed a vibration which appears to be coming from the rear of the car but it only occurs when over 50mph. I would have thought that if the isue were at the front of the car i would feel the vibration through the steering wheel but that is not the case.
I have jacked up all 4 wheels to check for any play and i cannot find any. My irst thoughts are to get tracking and wheel balancing done does that sond right?
cheers
iainlovatt
PostPosted: Tue Jun 12, 2012 4:56 am Up
checked tyres for uneven tyre wear?
Also could be a bearing
(My Garage)
10-1-1
PostPosted: Tue Jun 12, 2012 5:16 am Up
Sorry should have said, there is no uneven wear as far as i can tell.
thanks for the quick reply.
cheers
dafdavies
PostPosted: Tue Jun 12, 2012 6:26 am Up
it could be wheel balancing? If some one can confirm this
Team: If you cant find the tool you need make one
Lecktorious
PostPosted: Tue Jun 12, 2012 6:41 am Up
Trade Rating: +59
You might not be able to tell by looking at them. Check the wheel for any play and while it's on the jack swap the wheels about.
'98 Nile Blue 306 GTi 6
Sprotty
PostPosted: Tue Jun 12, 2012 7:10 am Up
I'd say wheel balance, probably thrown a weight off.
Life at full throttle...
PostPosted: Fri Jun 15, 2012 1:45 pm Up
Just like to say thanks for your help, had the wheels balanced 2 days ago and the vibration has all cleared up. However please check out my new problem posted above!?!?!?
cheers
