Latest: Puggingalong
Overall: 17129
Online Now [163]:
Visitors: 162
Today: 9943
Total: 101432146
Forums › The Car › Request a how-to › 206 1.9 2001 Brake Pipe Replacement?
Forum IndexRequest a how-to
mcburney777
PostPosted: Tue Jun 12, 2012 11:41 am Reply with quote Up
hello all,
car just failed mot on rear brake pipe being corroded, im wondering if any one could share a little information on how to change the brake pipes? is it hard and also would i b better of changing the whole lot?
any help is greatly appreciated.
chris
PostPosted: Tue Jun 12, 2012 11:47 am Reply with quote Up
You'll need a flaring kit, pipe cutter, brake pipe unions, pipe and fluid. It might work out less hassle to get a garage to do it rather than buying the tools.
For the pipe, fluid and unions go to your local motor factors, not Halfords.
mcburney777
PostPosted: Tue Jun 12, 2012 12:01 pm Reply with quote Up
thanks dude, yeah got all the tools i need of a friend of mine and have a we bit of xperience around the 206 but never brake pipes. its more the technique i need lol
and your right f*&^ halfords.
chris
  Quick Reply
Username:
Message:
Quote the last message
