Latest: flipflap
Overall: 17140
Online Now [256]:
Visitors: 255
Today: 95446
Total: 113895271
Forums › The Car › 206 Problems › Testing Injectors
Testing Injectors
PostPosted: Thu Jun 21, 2012 11:58 am Up
Right I seriously need to fix whatever my misfire is now. But How can I test the injectors?
Anybody have any ideas?
richpowell91
PostPosted: Thu Jun 21, 2012 12:30 pm Up
One quick test is to check the resistance between the two terminals, thats how i tested the two injectors that went on my car.
PostPosted: Thu Jun 21, 2012 1:53 pm Up
you need to get the flow test which you can't do it unless you got the machine
PostPosted: Thu Jun 21, 2012 1:56 pm Up
any idea where i could get it done?
PostPosted: Thu Jun 21, 2012 1:58 pm Up
no idea about petrol head.
but most diesel specialist got equipment to test my injectors
spike_202
PostPosted: Thu Jun 21, 2012 1:59 pm Up
Most remapping/tuning specialists do it
**spike's project**
TEAM:+200bhp
PostPosted: Thu Jun 21, 2012 2:01 pm Up
maybe ill just play blind & throw the set of spare injectors i have in see what happens then.
spike_202
PostPosted: Thu Jun 21, 2012 2:53 pm Up
As long as they are the same flow rate it should run fine.
**spike's project**
TEAM:+200bhp
PostPosted: Thu Jun 21, 2012 2:58 pm Up
There the injectors that came with the engine when i swapped it, so should be ok.
spike_202
PostPosted: Thu Jun 21, 2012 3:01 pm Up
Then should solve your problem IF it is your injectors at fault.
**spike's project**
TEAM:+200bhp
PostPosted: Thu Jun 21, 2012 6:56 pm Up
Don't know about petrol cars but diesels have a number stamped on each injector. Due to tiny manufacturing tolerance errors every injector flows a slightly different quantity of fuel and that number must be programmed to the ecu. The ecu then corrects for the fact that each injector is slightly different.
They will run without the ecu programmed with the new injectors but it is not wise to run like that for a long time. Are petrol injectors the same?
PostPosted: Fri Jun 22, 2012 5:36 am Up
This answered one of my question before Thumb Up
PostPosted: Fri Jun 22, 2012 12:12 pm Up
Read 'em and weep: www.youtube.com/watch?v=3mnA0cnXckg
and: www.youtube.com/watch?...ure=relmfu
