Posted: Thu Jul 12, 2012 1:43 am |
Got a rattling heat shield on the manifold of my gti 180. Bolts are too corroded to tighten. Has anyone just removed the heat shield without any issues?
| | ![](images/spacer.gif) |
Posted: Thu Jul 12, 2012 2:04 am |
I am pretty sure from what I have read on here before that you can just take these off no problems
Posted: Thu Jul 12, 2012 2:08 am |
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Thu Jul 12, 2012 2:13 am |
The heat shield is fine, just the bolts are knackered and worn.
Posted: Thu Jul 12, 2012 2:16 am |
Ah, just figured you might end up butchering it getting it off.
But yeah, if you can remove it, you can remove it, it should be fine to remove.
Wanted List;
Crystal Headlights.
Posted: Thu Jul 12, 2012 2:21 am |
Heat shield is different anyways!
Posted: Thu Jul 12, 2012 2:57 am |
It's been designed to protect something from the heat coming from the manifold. Car companies don't spend time and money doing research, design and manufacturing on something that isn't needed.
Clean up the threads and buy a new nut and bolt. Probably cost less than £1 to sort it out.
Posted: Thu Jul 12, 2012 4:51 am |
Jack123 wrote: |
http://www.ebay.co.uk/itm/Peugeot-206-Saxo-Exhaust-heat-shield-/251102405466?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot%7CModel%3A206&hash=item3a76dea35a#ht_500wt_1361 |
Lol, I cant imagine this fitting very well.
Posted: Thu Jul 12, 2012 5:45 am |
Got it sorted, managed to get the offending bolt out and replace it with a washer fitted aswell and all is good now!
