Posted: Thu Jul 05, 2012 2:14 pm |
Hi,
I am an owner of a 2002 206 1.6 16V XSI and I have been experiencing gearbox/clutch problems.
Firstly, 1st gear sometimes refuses to be selected and will not slot in. When setting off in that gear and going into 2nd, it makes a buzzing sound that comes from the near left side of the vehicle. It sounds like a mo-ped when setting off with a thrumming noise. As you can imagine, it’s pretty embarrassing setting off.
That’s not the only problem I have. My car will NOT slot into 5th gear. If I try to select 5th, on the move, it will just rev and not move the car forward – as if the car is in neutral and out of gear. So if I travel on faster roads, it means taking the car in 4th gear.
Has anyone else experienced these problems on their 206? If so, can you tell me or have an idea on what the faults could be on my car. If possible, on what the cost of the repair could be.
Feedback and answers will be much appreciated.
Posted: Thu Jul 05, 2012 4:19 pm |
need a gearbox overhaul+you have busted your 5th gear.
Posted: Thu Jul 05, 2012 5:28 pm |
A new gearbox is the only thing I can suggest, take it down to your garage and get a second opinion though (not a cowboy garage, mind)
| 2001, Silver 2Door, LX, 1.4 | |
Posted: Thu Jul 05, 2012 5:43 pm |
most garage won't touch gearbox (changing clutch doesn't count)
Posted: Thu Jul 05, 2012 6:34 pm |
AzMan wrote: |
A new gearbox is the only thing I can suggest, take it down to your garage and get a second opinion though (not a cowboy garage, mind) |
Replacing it will probably be a better (and possibly cheaper) solution than repairing the gearbox.
Posted: Sun Jul 22, 2012 2:19 pm |
Just an update, the gearbox has been sorted. Thanks for your help.
Posted: Mon Jul 23, 2012 5:34 am |
MackMac wrote: |
Just an update, the gearbox has been sorted. Thanks for your help. |
Eeerm..
And it was sorted by...? Doing what exactly?
Sorry for being nosey.
