Posted: Mon Jul 23, 2012 10:42 am |
Hello, can anyone tell me if the crank position sensor on Peugeots is on the top of the gearbox connected to a brown plug with gold contacts like this one? i1093.photobucket.com/...118b06.jpg
Cheers
Posted: Mon Jul 23, 2012 10:54 am |
Yes
Posted: Mon Jul 23, 2012 11:32 am |
Thanks mr bsi. A wiring diagram I found for my engine calls this an engine rpm sensor is this the same thing? Cheers
| 206 GTI 180
Micra 1.3 Turbo | |
Posted: Mon Jul 23, 2012 11:42 am |
TheWhiteRasta wrote: |
Thanks mr bsi. A wiring diagram I found for my engine calls this an engine rpm sensor is this the same thing? Cheers |
Yes, it sense's the teeth on the flywheel & uses the info to work out how fast the engine is turning.
Posted: Mon Jul 23, 2012 12:00 pm |
Thanks very much mr bsi this is why my engine won't start I'm missing a CPS I'm such a dumbass cheers
| 206 GTI 180
Micra 1.3 Turbo | |
Posted: Mon Jul 23, 2012 12:04 pm |
Engine ecu wont be able to see the engine is turning so it wont inject any fuel or fire the spark plugs
