Latest: Willy.Sea
Overall: 17168
Online Now [144]:
Visitors: 143
Today: 2086
Total: 128596518
Forums › The Car › 206 Problems › car steering
car steering
gaffa786
PostPosted: Fri Aug 17, 2012 6:15 pm Up
hi its mr problems again Smile
so my front tire had gone bold and i got it changed. well got the 2 front tires changed as thread was low and now the steering feels much better and can tell there is more grip however...............
when i am doing about 40+ it feels like the car is slightly moving left or right itself. bit hard to explain but its like it sways depending on the road. even if there is wind it feels as the car moves as it does not go straight.
could this be a wishbone problem perhaps.
thanks
PostPosted: Fri Aug 17, 2012 6:21 pm Up
could be.
but should check tracking first
gaffa786
PostPosted: Fri Aug 17, 2012 6:56 pm Up
Seabook wrote:
could be.
tracking seems fine/ if i let go of the steering wheel the car will go straight. it does also feel like the wheel gets pushed back when im at a stop and i am turning on to the road to go right it feels as the driver side wheels gets pushed.
also if i turn fast it feels as if the wheel wobbles
anton1989
PostPosted: Sat Aug 18, 2012 2:56 am Up
Trade Rating: +16
didnt you have this problem before and it was your wishbones? did you buy cheap ones?
PostPosted: Sat Aug 18, 2012 3:23 am Up
it could be top mount bearing if tracking was spot on.
i got that problem when mine exploded. it just pulled to one side randomly (especially after you steering a lot)
LeeMaddern
PostPosted: Sat Aug 18, 2012 5:12 am Up
My bet is wishbones or top mounts. Get both changed if i was you
More photos on FaceBook - www.facebook.com/lmaddern1
gaffa786
PostPosted: Sat Aug 18, 2012 10:18 am Up
Last time wid would happen when i accelerated and braked but its not like that now. And yes i did get it changed but that was the passenger side and that seems to be fine.
How much is it roughly for the top mounts suppplied and fitted
gaffa786
PostPosted: Sat Aug 18, 2012 10:35 am Up
