Latest: tbafonso
Overall: 17130
Online Now [256]:
Visitors: 255
Today: 16723
Total: 103752539
Forums › The Car › 206 Problems › broken temperature needle
nemesislee
PostPosted: Tue Aug 07, 2012 10:17 am Up
My temerature needle is doing my head in it keeps getting stuck. Does the needle control when the fan kicks in? Also if I was to replace the speedo can I get the mileage changed to what the car is?
peugeot 206 silver 1.4ltr lx
CAZ4708
PostPosted: Tue Aug 07, 2012 11:34 am Up
It depends on the year it was made.
PostPosted: Tue Aug 07, 2012 11:43 am Up
I think the BSI takes whatever milage is higher of the two dials and displays that.
CAZ4708
PostPosted: Tue Aug 07, 2012 11:51 am Up
This only applies to multiplexed 206's.
If you change the clocks in a preplexed 206, the mileage stays in the speedo memory.
Have you tried changing the needle?
PostPosted: Tue Aug 07, 2012 12:18 pm Up
& as normal on here the OP has given sod all information about the 206 they are having problems with Rolling Eyes
nemesislee
PostPosted: Tue Aug 07, 2012 12:43 pm Up
Its a w reg 2000 lx 1.4 3 door lol need any more info? Ive tried to fiddle the needle to get it working again but its just getting stuck. My mileage is digital and I have heard you can get it adjusted? If the needle is just an indicator of the temp and doesnt control the fan I can just leave it you see?
nemesislee
PostPosted: Tue Aug 07, 2012 1:47 pm Up
What plex would mine be? Its got two lots of cables which go into the back of the speedo.
nemesislee
PostPosted: Wed Aug 08, 2012 3:27 am Up
Any ideas then? Does it really matter if the temp needle does not work?
nemesislee
Dodgernator
PostPosted: Wed Aug 08, 2012 9:44 am Up
Yours is pre plex mate.
If you drive it around with the temp needle not working your engine could overheat without you knowing about it until it's too late.
Dodgernator
PostPosted: Wed Aug 08, 2012 9:51 am Up
You could change the speedo but you'll need one with a mileage close to your own and one with two plugs on the reverse.
I had a similar problem 12 months ago with mine. (floppy needles as it's known as)
Nick_C
PostPosted: Wed Aug 08, 2012 10:13 am Up
Fan is linked to sensor on rad so will still come on. Sure it's not the sensor that playing up on the engine?
Nick
Nick
Peugeot 206 GTI 180
Currently breaking a 2001 206 GTI - please contact for details/parts
nemesislee
PostPosted: Wed Aug 08, 2012 3:29 pm Up
Nah it's the needle when I get the front Perspex off and press around the needle it moves slightly but before it became totally stuck it did go to about 95 ish and the fan kicked in. Not really fussed if the needles don't kick the fan in. If its the sensor that does that then I can deal with it until I find he right mileage speedo. Cars never over heated on me comes close after a Long journey but fan always kicks in, so hopefully nothing to worry about then?
nemesislee
PostPosted: Wed Aug 08, 2012 3:32 pm Up
Also I was told by a French car garage that if I found a speedo which has covered less miles it would set to the current mileage on my old speedo, is this correct? So or example mine is at 110000 and the new one is at 80000 will it stay with 11000 miles when plugged in?.
nemesislee
PostPosted: Wed Aug 08, 2012 3:48 pm Up
