Posted: Tue Dec 14, 2010 8:48 am |
was wondering if u could get camber shims for 206 as i was told on rear torsion bar u cannot get camber??
can anyone shed any light on this for me
Posted: Tue Dec 14, 2010 8:49 am |
europug wrote: |
can anyone shed any light on this for me |
I have never seen any for them, you are right though the camber cannot be altered on the rear.
Posted: Tue Dec 14, 2010 8:50 am |
It can be done, but it depends on how much money and axles you want to lob at it to get camber
| Team Impossible Possible
Posted: Tue Dec 14, 2010 9:22 am |
fair enought not an easy job then
Posted: Tue Dec 14, 2010 9:24 am |
addaz wrote: |
It can be done, but it depends on how much money and axles you want to lob at it to get camber |
How do you do it then?? When i've had the wheels and everything off the stub pin and arm are solid, so how do you change the camber?
I ask out of intrest.
Posted: Tue Dec 14, 2010 9:30 am |
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Tue Dec 14, 2010 9:48 am |
Posted: Tue Dec 14, 2010 9:57 am |
How about caster?
Posted: Tue Dec 14, 2010 9:59 am |
Rob2859 wrote: |
How about caster? |
Im sure you cant adjust anything on the rear, its all set solid.
The only thing i could think of to change the camber/caster is to bend the stub pin, but that seems stupid to me.
Posted: Tue Dec 14, 2010 10:02 am |
Big_Rich180 wrote: |
Rob2859 wrote: |
How about caster? |
The only thing i could think of to change the camber/caster is to bend the stub pin, but that seems stupid to me. |
I was refering to the front so it gives the steering more weight and feel
Posted: Tue Dec 14, 2010 10:04 am |
Rob2859 wrote: |
Rob2859 wrote: |
How about caster? |
I was refering to the front so it gives the steering more weight and feel |
Rob, I've just read your sig. It's true!! I got home in record time on Monday Morning after leaving on Tuesday!!
Posted: Tue Dec 14, 2010 10:10 am |
Ape wrote: |
Rob2859 wrote: |
Rob2859 wrote: |
How about caster? |
Rob, I've just read your sig. It's true!! I got home in record time on Monday Morning after leaving on Tuesday!! |
useful consumer advice there
Posted: Tue Dec 14, 2010 10:15 am |
addaz wrote: |
I ask out of intrest. |
You would have to redesign the entire rear arms, one could be they are twisted but that may not be safe
Another could be machining out the rear stub so it has camber in the arms
Posted: Tue Dec 14, 2010 10:19 am |
addaz wrote: |
addaz wrote: |
Another could be machining out the rear stub so it has camber in the arms |
But then the bearings and stuff wouldnt fit on properly would they?
Sounds very dodgy to me either way, id leave it alone.
Posted: Tue Dec 14, 2010 10:25 am |
addaz wrote: |
addaz wrote: |
Sounds very dodgy to me either way, id leave it alone. |
Mate, i aint done it and frankly i aint trying it
Hence why i say YOU NEED A LOT OF MONEY, custom arms and bearings would be needed, not a simple case of machining out
