Forums › The Car › 206 Problems › 206 gti power steering pump |
Posted: Thu Aug 30, 2012 8:28 am |
Are these the same on all the gti's appart from the 180?
Posted: Thu Aug 30, 2012 12:22 pm |
Aren't the 180 pumps the same too?
