Online Now [58]:
Visitors: 57
Today: 2811
Total: 104953230
Forums › The Car › 206 Problems › kangaroo juice
kangaroo juice
shell-vt
PostPosted: Thu Aug 30, 2012 2:46 am Up
Trade Rating: +46
well were to start. my 206 2.0 16v was working really well, parked it up for a hour or so, then went back out , were ive noticed its not running as smooth as usual. kangaroo juice as we call it,, idle is arratic some times then car cuts out, it will start ok, but still kangaroo,s ... any ideas
thanks michelle..
york 16,3
Dillon
PostPosted: Thu Aug 30, 2012 3:00 am Up
Staff - Dillon
Coil pack I rekon.
Johnbyron
PostPosted: Thu Aug 30, 2012 3:07 am Up
Yep coil pack, a lad I work with has a 1.4 and his did this about a month ago, I said coilpack so he went and got a coilpack from scrappy for £10 and it worked Smile
shell-vt
PostPosted: Fri Aug 31, 2012 8:11 am Up
Trade Rating: +46
no its something to do with air flow
york 16,3
Johnbyron
PostPosted: Fri Aug 31, 2012 11:18 am Up
I wouldn't of thought so unless you know of something that would have restricted the air flow on you car recently
LeeMaddern
PostPosted: Fri Aug 31, 2012 1:12 pm Up
Air flow sensor. Idle control valve.
More photos on FaceBook - www.facebook.com/lmaddern1
shell-vt
PostPosted: Fri Aug 31, 2012 1:20 pm Up
Trade Rating: +46
not sure but its sucking in to much air from somewhere.. i carnt get it into the garage till late next week..
york 16,3
206boyracer
PostPosted: Fri Aug 31, 2012 3:52 pm Up
Too much air or too little fuel? My Astra did this when the fuel tank baffles came loose. Looking around on the vauxhall forums I found several things it could be before I checked the baffles.
Map sensor
Idle control valve
Egr valve
Throttle position sensor
Coolant temp sensor
Air leak
Fuel pump
Fuel leak allowing air into the injectors
Collapsed cat
I know it's not the same manufacturer but these can all cause kangarooing.
Hope something helps and you don't end up replacing everything like I did before finding out its something simple.
If its sucking too much air has the sensor fallen out of the inlet manifold or is the throttle body tightly bolted on?
206 GTI 138.
shell-vt
PostPosted: Mon Sep 03, 2012 1:34 pm Up
Trade Rating: +46
ive had it on diagnostics nothing came up really just manifold something, just carn,t remember ... but the fella who does my work says its sucking in to much air, rather gasket leaking or one of the pipes...
york 16,3
206boyracer
PostPosted: Mon Sep 03, 2012 2:15 pm Up
Probably the map sensor then. That's situated in the manifold and measures the air going into the engine. If its not reading it correct it will be over or under fuelling.
206 GTI 138.
shell-vt
PostPosted: Tue Sep 04, 2012 7:59 am Up
Trade Rating: +46
yer its what my other half says aswell.. just fitted a typhoon k,n induction kit and its worse than ever
york 16,3
