Posted: Wed Sep 12, 2012 3:37 pm |
ok so i have a chance to swap my headlights (frosted) with some crystals but i dont have the h7 adapter anywer in sight. i heard that it should be lying around under the bonnet is that true?
and how do i remove the stalk?
ps the other car is a plex and mine is pre plex
thanks
Posted: Wed Sep 12, 2012 3:52 pm |
Trade Rating: +16
how long you been on here and you havnt learned to search!
you cant just swap stalks frm non plex to plex or the other way around!
you wont have a h7 lead on your car, you need the adaptor
Posted: Wed Sep 12, 2012 3:54 pm |
i did searchit actually but i read that the leads are hidden somewhere just trying to clarify.
also read that people make it more complicated than it is so i dont no just need clear answers. not trring to be rude or annoy anyone
Posted: Wed Sep 12, 2012 4:31 pm |
Only on some models gaffa, about the time they just started
to make multi plex models, if you havent got the wiring. I highly suggest you see car electrician to wire it in for you.
I DO NOT WANT TO SEE ANOTHER THREAD FROM YOU SAYING YOU'VE SHORTED YOUR ECU AND BSI
Posted: Wed Sep 12, 2012 4:34 pm |
Trade Rating: +16
lol your not annoying me
i dont think you will have a h7 lead mate, im sure there is someone selling the lead you need, i think it was matt not to sure
and you 100% cant swap non plex and plex stalks around, why do you want to do that anyway?
Posted: Wed Sep 12, 2012 4:38 pm |
anton1989 wrote: |
and you 100% cant swap non plex and plex stalks around, why do you want to do that anyway? |
i heard you had to swap the stalk from searching the threads im not sure or that may be just for the fog lights :s
and no blown ecu threads lol
Posted: Wed Sep 12, 2012 4:41 pm |
Trade Rating: +16
looks like you did search
you need the stalk from a NON plex though not a plexed.
here is what you need to do
CLICK HERE
hope this helps
Posted: Wed Sep 12, 2012 6:01 pm |
anton1989 wrote: |
CLICK HERE
hope this helps |
but i thought all none plexed cars had frosted headlights?
Posted: Wed Sep 12, 2012 6:04 pm |
gaffa786 wrote: |
anton1989 wrote: |
CLICK HERE
hope this helps |
but i thought all none plexed cars had frosted headlights? |
GTI's came with crystals
I have a pre plex GTi stalk for sale
Posted: Wed Sep 12, 2012 6:06 pm |
LeeThr wrote: |
gaffa786 wrote: |
anton1989 wrote: |
CLICK HERE
hope this helps |
I have a pre plex GTi stalk for sale |
how much? and is installing it easy?
Posted: Thu Sep 13, 2012 5:02 am |
its unlikely you'll have the plug waiting for you. you dont need to change your stalk either, but if you dont you wont be able to have both dipped and main beam at the same time. even if you do change the stalk you will still need adapters for the crystal headlights. get the adapter, change the stalk (in answer to your question its very easy, just have to remove the cover around the back of the steering wheel and afew torx screws) and your sorted
| Black 206 Gti. Soon to be 2.2 | |
Posted: Thu Sep 13, 2012 5:54 am |
oldskoolz wrote: |
its unlikely you'll have the plug waiting for you. you dont need to change your stalk either, but if you dont you wont be able to have both dipped and main beam at the same time. even if you do change the stalk you will still need adapters for the crystal headlights. get the adapter, change the stalk (in answer to your question its very easy, just have to remove the cover around the back of the steering wheel and afew torx screws) and your sorted |
thabks for the reply cleared it up. where can i get the adapters from ?
Posted: Thu Sep 13, 2012 7:05 am |
gaffa786 wrote: |
oldskoolz wrote: |
thabks for the reply cleared it up. where can i get the adapters from ? |
Try the dealers. H7 plug part number was listed on the site somewhere.
Posted: Thu Sep 13, 2012 7:53 am |
macca1411 wrote: |
gaffa786 wrote: |
oldskoolz wrote: |
Try the dealers. H7 plug part number was listed on the site somewhere. |
if i get the plug from there will i need to cut the wire to put it on or would it just connect over my old one?
