Online Now [1149]:
Visitors: 1148
Today: 250331
Total: 149314162
Forums › The Car › 206 Problems › oil pressure switch..
KrishanK
PostPosted: Thu Sep 13, 2012 8:56 am Up
Can someone please tell me where the oil pressure switch/sensor is on my peugeot 206 1.4 hdi 2003. thanks.
Peugeot 206..But what\'s next?
PostPosted: Thu Sep 13, 2012 9:09 am Up
Next to the dipstick
KrishanK
PostPosted: Thu Sep 13, 2012 9:29 am Up
thanks...how do i remove it to replace it?
PostPosted: Thu Sep 13, 2012 10:34 am Up
Remove the wire and unscrew it. To refit do the opposite, replacing the sealing washer though.
bugawuga
PostPosted: Thu Sep 13, 2012 2:21 pm Up
It's a fiddly job but as above.
Make sure you put some news paper / old rags down as oil will drip when the sensor is removed.
KrishanK
PostPosted: Sat Oct 13, 2012 8:34 am Up
does anybody know which sock i need to remove it? the sensors hard to get to..
KrishanK
does anybody know which socket i need to remove it? the sensors hard to get to..
PostPosted: Sat Oct 13, 2012 8:43 am Up
Why dont you try your sockets on the new switch.
KrishanK
PostPosted: Sat Oct 13, 2012 8:46 am Up
i havent got the new one yet, its hard to get a socket deep enough to undo it, and cant get a spanner in either...
PostPosted: Sat Oct 13, 2012 8:48 am Up
Buy the new switch, take it to Halfords & find a deep socket that fits it, take the socket to the till & pay for it.
simonster_14
PostPosted: Sat Oct 13, 2012 10:20 am Up
i just did mine on a 1.6 hdi was a nightmare, i took the doser unit(if you have one off) on top of the engine,
took the aircondition pump (again if you have a/c)off underneath and pushed it out towards the wheel and took the altenator off.
this it was 22mm? i used a ring spanner to do mine
took me about 2 hours to do because i tested pressure same time...
id get a sensor from peugeot 1st because this is not a job you want to do twice
hope that helped:)
KrishanK
PostPosted: Fri Oct 19, 2012 5:44 am Up
hope that helped:)
thanks it did help, changed it.. the oil light has stopped coming, but the stop sign is still flashing away along with the temperature gauge flickering up and down...
PostPosted: Fri Oct 19, 2012 11:39 am Up
Sounds like your engine coolant temp sensor is disconnected.
KrishanK
PostPosted: Sat Oct 20, 2012 4:18 am Up
Where is the engine coolant temp sensor located and is it a long process to replace?
