Online Now [485]:
Visitors: 484
Today: 34931
Total: 105476960
Forums › The Car › 206 Talk › Unusual suspension question
Mounty
PostPosted: Fri Sep 21, 2012 2:16 pm Up
Recently got a 206 GTi for using in production car trials. I need to get the suspension raised up as much as possible and will be doing the torsion bars on the rear but need to get the front higher.
Will front springs off a 1.1 or 1.4 fit the Gti? If I can fit these I'll then add some Grayston spring assisters to keep the springs stretched.
Any ideas appreciated.
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
PostPosted: Fri Sep 21, 2012 2:44 pm Up
it will fit but why do you have to use the spring off a 1.1/1.4?
SinfulDesignCom
PostPosted: Fri Sep 21, 2012 4:10 pm Up
more importantly it will handle like a bag of sh*t Smile
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Mounty
PostPosted: Fri Sep 21, 2012 4:49 pm Up
Handling not an issue as its very low speed skill tests. Also disconnecting the rear ARB.
Can i get away with just a spring change or would you say damper as well.?
PostPosted: Fri Sep 21, 2012 4:56 pm Up
i don't understand what you want to do and why.
djdan0123
PostPosted: Fri Sep 21, 2012 5:52 pm Up
Confused.com more info please lol
Build your own dreams, or someone will hire you to build theirs.
Life's a gamble, Take your chances.
SinfulDesignCom
PostPosted: Fri Sep 21, 2012 6:17 pm Up
206 GTI... poverty springs... disconnect the rear ARB...
... that's one screwed up "production" car Smile
PostPosted: Sat Sep 22, 2012 1:51 am Up
If it's low speed then why does it matter whether it's low or high?
Also 1.1 springs might end up lower than standard GTi springs because of the extra weight.
Mounty
PostPosted: Sat Sep 22, 2012 2:42 am Up
I understand why this seems a daft idea, but the softer springs from lower spec models create an element of 'bounce' on the front which helps to get the car over some of the humps & hills.
The white AX GT and black Saxo VTR in this clip www.youtube.com/watch?v=TNqEvJNolWE have 1.1 front springs and ARB disconnected. More travel in the rear suspension is required so disconnecting ARB helps here.
Another clip here
www.youtube.com/watch?...=endscreen
This clip shows why I need more clearance
www.youtube.com/watch?v=LlAAKR-qG3M
Not everybody's cup of tea but intend to do this over winter and then lower it during summer for tarmac autosolos.
gaffa786
PostPosted: Sat Sep 22, 2012 6:29 am Up
SinfulDesignCom
PostPosted: Sat Sep 22, 2012 7:09 am Up
You need to think this through because if you remove the torsion bars altogether, hitting a bump at the right speed and you will smack the bump stops with the trailing arms - unless you have uprated shocks.
The front springs, I can see the logic...
...but I can't see the logic in a FWD going up a hill in the snow.
paul_c
PostPosted: Sat Sep 22, 2012 7:39 am Up
You guys don't understand, and haven't thought to Google, what "production car trials" are.
Why do you need the GTI, the 1.1 or 1.4 would probably do just as good a job?
PostPosted: Sat Sep 22, 2012 7:49 am Up
You cant remove torsion bars! They support the car - never mind when you hit a bump. Torsion bars also hold the traling arms onto the axle tube.
Uprated dampers dont restrict suspension travel either.
SinfulDesignCom
PostPosted: Sat Sep 22, 2012 8:23 am Up
I did once drive an AX GT 20 miles down the M62 with only axle and shocks... Bloody good fun. Nearly killed myself doing it, but fun nonetheless Smile
But joking aside... agreeing with Edward here. Removing the torision bars is a one-way ticket to looking a tit
PostPosted: Sat Sep 22, 2012 8:39 am Up
you need longer spring with longer travel dampers....not necessarily softer spring as you will bottom out the suspension
instead of removing the rear ARB, you should remove the front one to give you more road contact as yours aren't RWD....
and you need a clutch type diff as well
