Latest: sparrowdclxvi
Overall: 17139
Online Now [123]:
Visitors: 122
Today: 29607
Total: 113638460
Forums › The Car › 206 Problems › Car wont start
Car wont start
Domo
PostPosted: Tue Sep 25, 2012 3:43 am Up
It turns on and radio everything comes on. But it just wont up fire up. there's also a strong smell of petrol whilst it tries fire up. Any ideas?.
My car: 206 xs, 1999, 89k miles, 1.6 engine.
HDI90
PostPosted: Tue Sep 25, 2012 3:50 am Up
Could be 1001 things, check you got a spark first then go from there
GTI 180
PostPosted: Tue Sep 25, 2012 4:05 am Up
What was the last thing you did to the car before it stopped starting or has it just decided to pack up by itself overnight?
southwestchap
PostPosted: Tue Sep 25, 2012 4:57 am Up
fuel hose hasn't popped off the rail has it? had that once while driving a petrol...
Domo
PostPosted: Tue Sep 25, 2012 5:47 am Up
it just happened over night. smelled a bit last night when I parked, i thought it was a different car tho.
where abouts is that under the car? ill have a look when i get home.. had to use the bus today.. was s**te!
southwestchap
PostPosted: Tue Sep 25, 2012 6:03 am Up
unlucky, i have to get the bus most days so I know how you feel.
pretty sure that the fuel rail is on the back of the engine, though it won't be hard to see if there's petrol everywhere...
Domo
PostPosted: Tue Sep 25, 2012 6:11 am Up
its raining here and the weathers s**te. its not got puddle of rainbow juice sitting bout it so if it is leaking its not leaking really badly.
Domo
PostPosted: Tue Sep 25, 2012 7:11 am Up
Petrol smell is only there when the car is tryin to fire up
Steve180
PostPosted: Tue Sep 25, 2012 8:10 am Up
It might smell of fuel because the pump is dumping a bit into the cylinder but as its not being burnt as normal, its just sitting there, may even flood the engine eventually if there's not spark. Try plug change first, then look at coil pack and battery (may be that the charge is enough for radio but not enough for first fire).
If none of that works, get a diag done to see if there is a major underlying fault.
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
danhill87
PostPosted: Wed Sep 26, 2012 11:00 am Up
I got mine fixed today:
www.206info.co.uk/Foru...tml#554699
Quote::
Problem fixed, turned out to be a wiring bundle under the air filter box, that was encased in plastic tubing was filled with rain water and had corroded one of the wire until it had broken
Domo
PostPosted: Wed Sep 26, 2012 11:57 am Up
Got mine fixed yesterday. It finally stopped raining and the girlfriends dad popped round whilst i was working. Hada jump lead the car then he went to accelerate nd herd a fizzing noise looked under tge car and the feul line had popped out pishing feul everywere. Got it all connected up properly wich is gd. Cheers for the help anyways
