Latest: morgan20
Overall: 17135
Online Now [579]:
Visitors: 578
Today: 32066
Total: 110584254
Forums › The Car › 206 Problems › Wiper blades
Wiper blades
TJsmith
PostPosted: Mon Oct 01, 2012 1:27 pm Up
Need to get a new set as one has snapped off. They are currently aero blades but when I bought them both, the drivers side rubbed on the piller. The size I have on at the moment is 19/26.
Have done a number of searches on here, but can't get a definitive answer, can anyone advise?
Cars a 98 reg
Cheers
party7uk
PostPosted: Mon Oct 01, 2012 2:16 pm Up
if the car is right hand drive then both wipers should be the same size 55cms.
they should only be different sizes if the car is a left hand drive.
common mistake by part factors as they dont read the books properly
hello
PostPosted: Mon Oct 01, 2012 2:19 pm Up
nope.
old 206 use 19/26 blade; new 206 use 22/22 blade.
party7uk
PostPosted: Mon Oct 01, 2012 3:12 pm Up
yes.
they should all be 55cms .
only lefthand drive use 19/26.
check out peugeot parts.
all uk use 55cm blades.
see this problem all the time when i fail 206 on insufficient swept area in front of driver.
hello
PostPosted: Mon Oct 01, 2012 3:19 pm Up
i am sick at repeating my answer.
left hand drive 206 use 26/16 and i have to say you are wrong.
if in doubt check the peugeot manual.
party7uk
PostPosted: Mon Oct 01, 2012 3:27 pm Up
ok, i was wrong
i do apologise.
all depends on build code.
and there are 3 sizes of drivers blades and 2 on passenger side.
06
6426 V0
RP 6423 G5
01
01 BRUSH
LONG 480
- RIGHT HAND DRIVE UNTIL RPO No. 08469
"DRIVERS SIDE"
E 429 006
01 WIPER BLADE
LONG 465
- RIGHT HAND DRIVE UNTIL RPO No. 08469 AND AGE >= 5
6426 GA
01 BRUSH
LONG 550 SPOILER
- RIGHT HAND DRIVE SINCE RPO No. 08470
"DRIVERS SIDE"
07
6426 V7
RP 6423 G8
01
01 WIND WIPR BLADE
LEFT
LONG 650
"PASSENGER SIDE"
6426 GC
RP 6426 S4
01
01 BRUSH
LONG 550
"PASSENGER SIDE"
hello
PostPosted: Mon Oct 01, 2012 3:28 pm Up
no worries.
glad that everything is clear now.
party7uk
PostPosted: Mon Oct 01, 2012 3:32 pm Up
hopefully the screen
hello
PostPosted: Mon Oct 01, 2012 3:52 pm Up
Simple answer is if one is too long, just buy one an inch or two shorter. Not really rocket science.
It's well known on here that if your car is listed as needing 22" then you buy 21" aeroflats to solve the overhang problem. The same theory can be applied to the early 206s
