Forums › The Car › 206 Problems › Renew glow plugs? |
Posted: Wed Oct 03, 2012 2:24 pm |
Hey, I read somewhere that you should change your glow plugs every 60,000 miles. Is this true? If not, then what should I do to make sure my car is ready for winter in the glow plug department?
Posted: Wed Oct 03, 2012 2:32 pm |
They only need replacing when they don't work.
Posted: Wed Oct 03, 2012 3:19 pm |
How often should I test them?
| DIY maintenance on my 206 | |
Posted: Wed Oct 03, 2012 4:05 pm |
depends what engine have you got.
the 1.4 and 2.0 HDi you can wait till difficult start during winter.
if you got the 1.6 HDi you better replace it every 60000 miles as they are required for the dpf regen; they aren't expensive to replace anyway
Posted: Thu Oct 04, 2012 7:10 pm |
Well, its a 1.4 HDi, so I guess that means I wait until a problem in winter
