Latest: Puggingalong
Overall: 17129
Online Now [212]:
Visitors: 211
Today: 41954
Total: 101334885
Forums › The Car › 206 Problems › The key remote is not working, any suggestions?
hamed206
PostPosted: Mon Oct 22, 2012 1:49 am Up
The key remote that is used to open the doors is not working. Even the red light in the button stopped flashing or lighting. I replaced the battery, but no hope.
I just like opening the doors using the remote!.
Car is 2000 model, 1.4 8v.
What could the problem be?
Thanks.
Hamed
iainlovatt
PostPosted: Mon Oct 22, 2012 2:36 am Up
could be the board! car still runs ye?
(My Garage)
Deckchair5
PostPosted: Mon Oct 22, 2012 2:38 am Up
If you replaced the fob battery and the fob light still isn't working then you either
put in a bad battery ( check voltage)
inserted the battery incorrectly or it's not making contact ( try again)
fob button is bad- check it out
or the fob circuit board is bad
hamed206
PostPosted: Mon Oct 22, 2012 3:23 am Up
No problem with the car. The problem is in the key! opening and closing the door with the button is no longer working.
Hamed
iainlovatt
PostPosted: Mon Oct 22, 2012 3:42 am Up
So it means its the board, look through the how to and see if you can re programme it?
(My Garage)
hamed206
PostPosted: Mon Oct 22, 2012 4:04 am Up
I know how to re programme, but it didn't work.
The red led is not even flashing or making an indication that the key is working.
Hamed
PostPosted: Mon Oct 22, 2012 5:05 am Up
yEP.
hamed206
PostPosted: Mon Oct 22, 2012 5:18 am Up
I tried new battery, I checked the button, I even tried to push directly through the internal button.
Sounds the board then.
But the key was working. I just wanted to change the battery because the distance were becomming bad. After I changed the battery, nothing is working. I tried with the old battery, nothing too!.
Hamed
iainlovatt
PostPosted: Mon Oct 22, 2012 5:19 am Up
2 options then
1) battery is in wrong, or is already dead, Most probably..
2) board is bust and you need another one which isnt cheap!!
(My Garage)
hamed206
PostPosted: Mon Oct 22, 2012 5:47 am Up
iainlovatt wrote:
2 options then
If the board I'm lost.
And thanks all for the advises.
Hamed
PostPosted: Mon Oct 22, 2012 7:45 am Up
No further production, once Peugeot's stock is all used up thats it for non plexed remote keyfobs Laughing
hamed206
PostPosted: Mon Oct 22, 2012 8:05 am Up
Thanks for the info dude!.
Hamed
