Latest: morgan20
Overall: 17135
Online Now [259]:
Visitors: 258
Today: 3679
Total: 110715284
Forums › The Car › 206 Problems › Big probs now!!
Big probs now!!
karimali831
PostPosted: Fri Oct 19, 2012 12:17 pm Up
This is second time now when crawling I put main beam on (just installed with hid) and the engine stalls very erratically with oil pressure insufficient warning. the oil is very erratic but there is enough of it in it.. When the high speed fan turns on also the revs drops and engine judders. I'm running 2 amps, full hid, 2 din, 1000w sub, interior lighting now it seems there is too much of it it stalls?? The electronics seems very dodgy, ALL errors can illuminate on mfd and dash then disappear when I restart engine. I feel like stripping to standard now to get back to normal. I'm sure also everything is wired correctly. Any advise on this?
Thanks all
206 GTI 180
PostPosted: Fri Oct 19, 2012 12:27 pm Up
Where have you mounted the ballasts?
karimali831
PostPosted: Fri Oct 19, 2012 12:30 pm Up
oh this matters? I just trapped them together on the side underneath the wing. Very Happy
206 GTI 180
anton1989
PostPosted: Fri Oct 19, 2012 12:31 pm Up
Trade Rating: +16
could it be your battery or alternator?
PostPosted: Fri Oct 19, 2012 12:33 pm Up
The ballasts create a strong electro magnetic field and need to be placed away from the ECU and the looms.
karimali831
PostPosted: Fri Oct 19, 2012 12:34 pm Up
the alternator is okay and the battery is new - feb this year but it is from the AA so I am not sure if I need a better battery, how can I check?
It will always say oil pressure insufficient when main beam comes on when I am crawling.
206 GTI 180
PostPosted: Fri Oct 19, 2012 12:38 pm Up
especially cheap HID ballasts Cool
karimali831
where can I find the ECU on a 180?
206 GTI 180
PostPosted: Fri Oct 19, 2012 12:48 pm Up
behind passenger side headlight....
anton1989
Trade Rating: +16
under the bonnet Laughing
karimali831
PostPosted: Fri Oct 19, 2012 12:49 pm Up
yes I thought so, just making sure!! Embarassed
thanks...
206 GTI 180
anton1989
PostPosted: Fri Oct 19, 2012 12:51 pm Up
Trade Rating: +16
i would remove the hids and see if you still get the problem, if you dont then you know what the problem is?
karimali831
PostPosted: Fri Oct 19, 2012 1:09 pm Up
great moved it a 2-3 inches away, not stalling anymore Smile
But when I turn the aircon on and main beam, (again only when driving very slow) the main beam lights were flashing in sequence with high pitch sound coming from the speakers, I could hear engine/ignition noises from the speakers like fans and clicks. After another minute of driving it seemed all okay but there is an annoying high pitch sound when I turn unit off/on. This high pitch sound I'm sure is linked to where all the errors show up.
206 GTI 180
anton1989
PostPosted: Fri Oct 19, 2012 1:38 pm Up
Trade Rating: +16
sounds like your rca cable is near your power cable (for the amp)
PostPosted: Fri Oct 19, 2012 2:02 pm Up
People using cheap electrical components
