Latest: tbafonso
Overall: 17130
Online Now [257]:
Visitors: 256
Today: 5615
Total: 103591461
Forums › The Car › 206 Talk › Where can I buy this part
ruby_the_206
PostPosted: Sun Oct 21, 2012 4:37 am Up
Hi ive been looking for this part online but cant find anything
Basically in passenger footwell there has been water quite alot of it but only when its been raining! So I checked under car and I can see that 3 of the rubber plugs have gone the ones that drain the water! Is there a specific name for them and anyone no where I can get them from peugeot dealer had no idea wot I was on about.
Ruby
PostPosted: Sun Oct 21, 2012 5:17 am Up
I dont think they'll remedy your problem. More than likely your door seal.
PostPosted: Sun Oct 21, 2012 5:19 am Up
Rubber grommets?
Are you sure the water is coming from underneath.
Leaking aerials and the door card liner not being sealed are the usual causes of wet footwells. Check the drain holes under the doors too. They can get blocked but once cleared are sufficient for draining water from the doors.
ruby_the_206
PostPosted: Sun Oct 21, 2012 5:30 am Up
Nope def the plugs as its everytime I drive through a puddle and there is basiclly 3 holes in floor water also only in middle not round sides so yeah it the plugs
Ruby
