Latest: tbafonso
Overall: 17130
Online Now [208]:
Visitors: 207
Today: 69566
Total: 103578751
Forums › The Car › 206 Problems › Cooling fan on constantly
Ruins3696
PostPosted: Sat Oct 27, 2012 3:21 pm Up
Hi all my v reg 206 cooling fan comes on as soon as you turn
The ignition on was told it might be radiator fan switch but it doesn't have one
Anybody got any ideas how to sort this out as concerned that fan may burn out
Not air con either as made sure air con wasn't on
PostPosted: Sat Oct 27, 2012 4:08 pm Up
Relay could be stuck or the coolant temp sensor might not be working so the ECU keeps the fan on to make sure the engine doesn't get too hot.
Ruins3696
PostPosted: Sun Oct 28, 2012 2:37 am Up
Any idea Where would I find these on the car
iSamTz
PostPosted: Sun Oct 28, 2012 3:38 am Up
Trade Rating: -1
My old mates car done this.. he put some water in it and fixed the problem.. just wondering if you've tried the obvious?
206 1.4 2002 - Project Car
BMW 116 2012 - Work car
Yamaha R1 - Race bike (snetterton, Cadwell)
