Latest: airmastertapes
Overall: 17133
Online Now [63]:
Visitors: 62
Today: 4170
Total: 106668432
Forums › The Car › 206 Problems › MOT FAIL!! Help with costs please!!!
Go to page 1, 2, 3  Next
niki945
PostPosted: Sat Nov 03, 2012 8:24 am Up
My 206 has just failed its MOT quite badly, so just need to know how much I'm looking at for repairs as a guide (going back to the garage next week!)
Here's the main things it failed on....
- front anti roll bar linkage has excessive play ina pin/bush 2.4.G.2
- Offside front anti roll bar linkage has excessive play ina pin/bush 2.4.G.2
- Offside front anti roll bar linkage ball dust cover excessively damaged so that it no longer prevents the ingress of dirt 2.4.G.2
- Parking brake lever has no reserve travel 3.1.6b
- Rear brake application uneven 3.7.A.5c
- Parking brake efficiency below requirements 3.7.A.10
Seriously on the verge of a mental breakdown at how much this is gonna cost! Any advice muchos appreciated :o)
broadblaster
PostPosted: Sat Nov 03, 2012 8:35 am Up
both anti roll bar links are uder £20 from euro car parts
brakes will need strip down and cleaning new shoes/pads are quite cheap then rebuild and readjust the handbrake.
tbh its not that bad a list looks alot worse than it is.
are you doing yourself or getting garage to sort for you as that will be your biggest cost the parts are cheap its the labour cost that add up.
on a back road playing
PostPosted: Sat Nov 03, 2012 8:37 am Up
2 new front drop links. £40 fitted? Rear brake shoes need changing hand brake adjusting. Wouldn't cost much I would have thought.
broadblaster
PostPosted: Sat Nov 03, 2012 8:39 am Up
you could go onto euro car parts website put in your reg and get the price for the parts then you will have a rough idea of parts cost.
niki945
PostPosted: Sat Nov 03, 2012 8:54 am Up
Ill be getting all done at a garage- I don't know how to change a bulb never mind anything else ha! So scared I'm gonna get rinsed for hundreds- he said its half a days work x
broadblaster
PostPosted: Sat Nov 03, 2012 8:59 am Up
that sounds about right time wise as said parts will be 40-60 ish depending on where they get them from but if local motor factors (like most garages) that should be about right.
then its down to there labour costs
niki945
PostPosted: Sat Nov 03, 2012 9:04 am Up
So do you think inc labour it should be under £300?
Nicola xxxxxx
broadblaster
PostPosted: Sat Nov 03, 2012 9:06 am Up
would like to think half that !!!!!
niki945
PostPosted: Sat Nov 03, 2012 9:17 am Up
Ah really, was scared my credit card was gonna have to take the beating of its life!!! Ha
Nicola xxxxxx
broadblaster
PostPosted: Sat Nov 03, 2012 9:21 am Up
they should be able to give you a quote before they do the work, so if it seems a bit steep try elsewhere.
but its all easy work to sort out do you not have a mate/family member that could do the work for you for beer tokens.
niki945
PostPosted: Sat Nov 03, 2012 9:24 am Up
No I don't know anyone who could fix it on the cheap unfortunately! :o(
Nicola xxxxxx
broadblaster
PostPosted: Sat Nov 03, 2012 9:28 am Up
you could allway put a thread up on here aksing if any in your area would be willing help you out.
or if they know of any garages that will not rip you off.
as said really its only simple jobs nothing majors at all.
PostPosted: Sat Nov 03, 2012 9:35 am Up
drop link will be 10-20 each;
about the rear brakes it depends whether you got drum or disc.
for drums it will be more expensive; drum will be around 40 each and shoe will be 30 per axle; bearing will 15 each.
disc i think is around 40 per axle and around 20 for pads.
around 1 hr labor top i guess?
PostPosted: Sat Nov 03, 2012 9:37 am Up
Nice to see another well maintained 206 on here Rolling Eyes
niki945
PostPosted: Sat Nov 03, 2012 9:41 am Up
Bore off if you have nothing constructive to say. Muppet
Nicola xxxxxx
Page 1 of 3
