Posted: Sat Nov 24, 2012 5:28 am |
are these interchangeable. ie can i get one from the scrappy and simply swap over or is some daft coding required?
Posted: Sat Nov 24, 2012 8:11 am |
Daft coding required.
Better to replace ECU/BSI + key.
Posted: Mon Nov 26, 2012 2:29 am |
Then that will mean ignitin petrol cap, door looks, boot lock wont it ?
Posted: Mon Nov 26, 2012 4:28 am |
You only need the electronics from the key, so you can swap the blade over to keep the original locks.
I think making the note of the VIN from the donor car is advantageous for future use.
Posted: Mon Nov 26, 2012 1:30 pm |
macca1411 wrote: |
I think making the note of the VIN from the donor car is advantageous for future use. |
Absolutely, and any half-decent supplier does this.
