Latest: Puggingalong
Overall: 17129
Online Now [468]:
Visitors: 467
Today: 53758
Total: 101475894
Forums › The Car › 206 Talk › Seatbelt connector plug
karimali831
PostPosted: Sun Dec 16, 2012 5:59 pm Up
Replaced the drivers seat from a 180 model with the same seat but RC, (shows RC badge on the seat) and the problem is the seatbelt connector plug won't go in. The plug design is only slightly different, is it ok to cut the wires and connect together?
206 GTI 180
PostPosted: Mon Dec 17, 2012 2:41 am Up
Look on Service box at the plugs and connectors. Might be able to get the correct plug and terminal.
