Latest: ArtistKS
Overall: 17145
Online Now [35]:
Visitors: 34
Today: 11534
Total: 115952480
Forums › The Car › 206 Problems › Temperature gauge issue
dafatkid88
PostPosted: Sat Dec 15, 2012 12:26 am Up
Heya guys..
I have a 53 plate 206 gti180 & since the other day my temp gauge on the dash has been intermittently cutting out for a few seconds and then coming back on and cutting out again
I've made sure the coolant is topped up & checked the fuses but still can't see what's wrong
Would it be a case of needing a new sensor do you think? Or could it be something else?
Also im worried my fan may not work because of this?
Any help is much appreciated Smile thanks in advance
GTi180 - FOX 17" Gloss White Rims, FK-AK Coilovers, Powerflow Stainless Steel Cat Back, Limo Tints, Morettes, Badgless Grill
dafatkid88
PostPosted: Sat Dec 15, 2012 3:34 pm Up
Anyone? Sad
bezford
PostPosted: Sat Dec 15, 2012 4:21 pm Up
Its a wiring fault or a thermostat needing renewing ...put a thermostat in and check for earth connection problems then check for readings with a multimeter or test lamp on the wires to the temp sensor and see wot u get......
failing this u need to get the codes checked mate.
R.HYDE
