Latest: sparrowdclxvi
Overall: 17139
Online Now [71]:
Visitors: 70
Today: 476
Total: 113276076
Forums › The Car › 206 Problems › Stoopid Fob
Stoopid Fob
KStenton
PostPosted: Wed Jan 02, 2013 12:39 pm Up
Hey
So heres what i did without thinking, I have a key with remote central locking but my case was a degrading, had a button missing etc so i bought a new case, that has the two sides and an uncut blade.
so it came - i opened up my old one, swapped the board containing the bat (the whole thing) over to the new case, swapped the key blade over. Went outside, opened my car, got in, turn key, nothing.
Started motor is going, no spark. Oh no, i'd just immbolised my engine. Lucky i had a spare non remote key at home, got it turned the car on right away, fires no probem. Now, im guessing the chip in my remote key has reset for some strange reason even though it still unlocks my car?
And without going to a pug specialist, how would i go about making my car realise again its just me with a new platic housing on my remote key?
Cheers
Very Happy
First Pug: 206 1.4 LX 02 Grey
Bits done:
Performance:
Stainless Powerflow Exhaust System.
Cold Air intake System with Enclosed Filter.
Lowered 40mm on Springs
Visual:
Wind Deflectors, black trims. Xenon bulbs. Black Lexus lights.
Interior:
Blue interior lighted footwells and behind seats.
Bits to do: (for now)
Black alloy wheels
Tint Windows
Change Headlights
KStenton
PostPosted: Wed Jan 02, 2013 12:44 pm Up
Sorry posted twice becuase of the stupid security thing.
PostPosted: Wed Jan 02, 2013 12:56 pm Up
Sure you've not left the chip in the original key? Or not put the chip in the right place?
PostPosted: Wed Jan 02, 2013 12:57 pm Up
Did you swap the little black transponder chip that hides in the corner of the case over?
KStenton
PostPosted: Wed Jan 02, 2013 1:18 pm Up
Ah I might have missdd the black thing I'll have to check tommrrow. Cheers
Bits done:
Performance:
Visual:
Interior:
Black alloy wheels
Tint Windows
Change Headlights
PostPosted: Wed Jan 02, 2013 1:46 pm Up
I'm gonna say the same as guys said,I think that you forgot to swap the immobilser Chip,because replacing the cover won't make the immobilser not working,but regarding the key fob not working,you can do this:
1. Insert the Ignition Key.
2. Press the small Black button (Lock Button)
3. Switch the Ignition ON
4. Keep the lock button pressed for 10 seconds.
5. Release lock button , switch ignition OFF and remove key.
6. Close all doors and press the lock button 2 times.
NOTE : If PLIPS still do not work, start the vehicle and then turn OFF. Open and close the door, and check PLIP again.
KStenton
PostPosted: Wed Jan 02, 2013 2:34 pm Up
Just found a picture of an open fob on the web, looks like i missed the little black chip. Feel real stupid now. Thanks a lot for the help.
Karl
PostPosted: Wed Jan 02, 2013 3:00 pm Up
good to know Smile
Thedevonian
PostPosted: Wed Jan 02, 2013 3:47 pm Up
Yep you are not the only one, same thing happened to me and I should have known about the transponder. I threw away my old key case before realising; luckily the bins hadn't been collected so we were able to retrieve it after searching a few black bags (not nice!). Embarassed
2008, 206 1.4 Look
