Latest: tbafonso
Overall: 17130
Online Now [242]:
Visitors: 241
Today: 11201
Total: 101923606
Forums › The Car › 206 Problems › car won't start when cold
omricn
PostPosted: Mon Dec 17, 2012 6:03 am Up
Hey guys,
I own a 2001 206 xsi.
This morning when I was ready to go to work I got in the car, turned on the ignition - everything seemed OK, lights switch on etc. when I tried to turn it on the starter just turned around and around and the car didn't start, I managed to start it in second gear in a downhill and drove straight to my mechanic, which said the battery and the alternator are fine. he can't connect the car to a computer, I need to go to another mechanic for that, and will do it tomorrow morning if the issue repeats itself.
Once the engine has warmed up it will start immediately, issue only happens when car is cold.
Any thoughts?
Tolkienfan001
PostPosted: Mon Dec 17, 2012 6:20 am Up
Trade Rating: +13
My Astra did this. It was the starter motor.
2005 1.4 16v Sport
Check out my 206 here!
omricn
PostPosted: Mon Dec 17, 2012 6:32 am Up
No way dude, starter is working fine, spinning just fine. Also it is about 2 years old, its the fastest starter I've ever had, one turn and the engine is on
Tolkienfan001
PostPosted: Mon Dec 17, 2012 6:41 am Up
Trade Rating: +13
Plugs? Coil pack?
2005 1.4 16v Sport
omricn
PostPosted: Mon Dec 17, 2012 6:43 am Up
If it were the plugs/coil pack I would be having issues other than cold starting.
Other than cold starting issue the car runs fine
Tolkienfan001
PostPosted: Mon Dec 17, 2012 7:06 am Up
Trade Rating: +13
If it started when bump starting but not with the Key. Surley it's an electrical fault??
2005 1.4 16v Sport
PostPosted: Mon Dec 17, 2012 7:09 am Up
Checked the earth cable on the gearbox?
omricn
PostPosted: Mon Dec 17, 2012 7:13 am Up
Could be allot of things, could be engine not getting fuel\air, could be some sensor causing this, another thing to remember is that this happens ONLY when engine is cold.. so I tend to believe its some kind of sensor
omricn
PostPosted: Mon Dec 17, 2012 9:53 am Up
I'm still at work, couldn't take the pressure anymore, it's quite cold outside so went to give it a try and the car starts, no problem what so ever, tomorrow morning will be the next test I guess..
TNX for the replies guys Smile
PostPosted: Mon Dec 17, 2012 9:55 am Up
Engine temp sensor possibly?
Check tomorrow.
omricn
PostPosted: Mon Dec 17, 2012 10:03 am Up
Check tomorrow.
Is there a way to check if it's OK? is it reachable?
bezford
PostPosted: Mon Dec 17, 2012 3:43 pm Up
The batteries dont like the cold weather...if you put a jump pack or leads to a car it will start basically showing that a better battery should solve this problem...im in a similar boat just waiting to get funds for a better battery as im getting tick over and weak battery symptoms...if u get codes can u put them up on here mate...cheers...
R.HYDE
PostPosted: Tue Dec 18, 2012 9:07 am Up
omricn wrote:
Check tomorrow.
Should be reachable but the best way is to read the live-data with a diagnostic tool and see what value the ECU see's.
I don't think battery is the problem in this case tbh.
novatron1_2
PostPosted: Thu Dec 27, 2012 6:01 pm Up
V9977 wrote:
omricn wrote:
Check tomorrow.
Try one of the cheap bluetooth OBD readers from ebay and the 'torque' app for your phone, well worth the money!
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
