Online Now [88]:
Visitors: 88
Today: 14255
Total: 106143965
Forums › The Car › 206 Talk › GTi power steering pipework
Mounty
PostPosted: Mon Oct 22, 2012 4:38 pm Up
Underneath the front valance on the GTi is a low slung metal pipe from the power steering reservoir. It sits just below the front splitter on mine at its lowest point.
Previous owner obviously knocked it on a speed bump or similar and there is a slight leek in the pipe. Struggling to get hold of one of these and wondered if I could cut an 18" length out and replace with a rubber hose so its flexible if it gets scraped. Pretty certain this is a low pressure pipe?
Probably a reason why I cant which is why I'm appealing to the greater knowledge of the forum Wink
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
PostPosted: Mon Oct 22, 2012 5:09 pm Up
I can get the pipe off the GTi im breaking for a few £ if you want
Mounty
PostPosted: Mon Oct 22, 2012 5:15 pm Up
Any idea how much??
PostPosted: Mon Oct 22, 2012 5:20 pm Up
Need to see which pipe it is so I can work out postage costs
Mounty
PostPosted: Mon Oct 22, 2012 5:30 pm Up
I'll let you know via pic or diagram but will be a few days. From memory may be an awkward shape to post??
Any thoughts on a rubber hose?
Baz.rsv
PostPosted: Mon Oct 22, 2012 11:40 pm Up
If the high pressure ones going,I would be interested in that if it's not spoken for an it's good nick mate.
southwestchap
PostPosted: Tue Oct 23, 2012 8:44 am Up
what about using hydraulic hose like whats used on tractor loaders? that there would sustain the pressure (if it was a high pressure pipe)
Mounty
PostPosted: Tue Oct 23, 2012 2:50 pm Up
Well, thats what I was wondering, even if it was just the lowest part of the pipework it would be a bit more flexible if it catches anything. Just really wanted to confirm that it is possible or if there is a reason I can't do it. It would be a cheap repair if nothing else.
PostPosted: Tue Oct 23, 2012 3:54 pm Up
WHich hose is it? The shiny one or the rougher grey one?
Mounty
PostPosted: Tue Oct 23, 2012 4:05 pm Up
It's a black pipe. The pipe that is split runs parallel with the bottom of the front spoiler on mine.
Mounty
PostPosted: Fri Nov 16, 2012 1:32 pm Up
Turns out that pipe is the radiator pipe to keep PAS fluid cool. Cut through it wit a pipe cutter and repaired with a bit of rubber hose and 2 jubilees. Seems to be holding up.
PostPosted: Fri Nov 16, 2012 4:37 pm Up
Is it the metal pipe that's split directly behind the bumper? I've got an immaculate one removed from my car.
Mounty
PostPosted: Sat Nov 17, 2012 6:55 am Up
Yeah, that sounds like the one. I'll keep it in mind, got an event o tomorrow so will see how the repair holds up but may be interested if it gives way.
Any idea how much?
PostPosted: Sat Nov 17, 2012 10:15 am Up
£15+postage? It is very clean. It's not been cut off either and come with the hoses right up to the PAS pump and where it joins the metal pipe under the sump. All the clips were prized off so just need replacing with jubilee clips.
Mounty
PostPosted: Sat Nov 17, 2012 12:25 pm Up
Yep, thats the one. Looks like a sh*t to post
