Latest: sparrowdclxvi
Overall: 17139
Online Now [80]:
Visitors: 80
Today: 28598
Total: 113268851
Forums › The Car › 206 Problems › strange electrical issue
weejoe86
PostPosted: Sun Dec 30, 2012 11:25 am Up
Hopefully someone can help. I have been told that my indicator illuminates slightly when car is in reverse. It only happens in reverse. Its fine in all other gears. Could it be the comms unit on steering wheel as sometimes after indicating it puts on main beams by itself!
Any advice appreciated
2.0 SW HDi Quiksilver
PostPosted: Sun Dec 30, 2012 11:30 am Up
Rear indicator? If so check the connections behind the light unit especially the earth.
Used to be common fault on Fords. Brake and the indicator lights up, indicate and the side light flashed. Nearly always came down to being a bad earth.
PostPosted: Sun Dec 30, 2012 11:36 am Up
^Precisely
weejoe86
PostPosted: Sun Dec 30, 2012 12:36 pm Up
I should have said. It is the the front indicator light that comes on. It doesn't come on fully but enough to be noticed.
