Latest: Beduff1977
Overall: 17134
Online Now [100]:
Visitors: 99
Today: 16255
Total: 107121758
Forums › The Car › 206 Problems › DAM DAM DAM
DAM DAM DAM
sheerness
PostPosted: Sun Jan 06, 2013 6:40 am Up
ello pug friends, I am trying to get access the the ecu with the pp2000 software, I am able to do some things, but i do get the message saying "no reply from ECU" I have put the pic here off all the numbers that I can find, but I dont know if any of them are correct, can anyone help me out with this? do you think that the DAM numbers will let the ECU's respond?....
thanks in advance
Dom.....
PostPosted: Sun Jan 06, 2013 7:04 am Up
8628 is the number you need along with your chassis number
Does it not even connect if you do a global test?
Are you using genuine software and Lexia lead or is it a Chinese clone?
sheerness
PostPosted: Sun Jan 06, 2013 7:23 am Up
yes it does connect to global test and we do get the faults that we fix and clear, but just no reply which is kinda odd, plus there are somethings that are grayed out so with the dam number which you helped us with will show everything, fingrs crossed, yes i am using genuine software & Lexia leads
thanks for that i will go back to the car now and see how it goes and let you know...
KR
Dom.....
vanepico
PostPosted: Sun Jan 06, 2013 12:48 pm Up
how do you tell the difference between a genuine one and a chinese copy lexia?
